Winter Tire package
Did anyone yet purchase the Audi recommended winter wheel and tire package from their dealer? For my 2012 Prestige it seems like it includes the stock 8.0J x 18 ET39 alloys with 225/50 R18 99H Pirelli Winter SOTTOZERO™ SERIES II tires + 24 month road hazard warranty.
Price seems a bit high compared to packages on Tire rack or other sites - although there you don't get the Audi wheel. I'm not sure about the 225/50 R18 99H Pirelli Winter SOTTOZERO™ SERIE II tires. Seem just OK depending on what site survey you read.
1. Any experiences with that tire versus others?
2. Why the change in tire size versus the stock 24/45/18 Continentals.
3. Any thoughts / guidance ? THANKS
To answer you sizing question you have to consider what is technically referred to as "floatation". If you need low ground pressure to float across soft surfaces (think of muddy farm fields or construction sites) you go with a wider tire with a bigger foot print. However in snow, you want the tires to bite down through the loose snow to find the hard pack or ice beneath in order to get traction. For this reason, you go with a narrower tire with higher ground pressure and lower "floatation".
Has anyone purchased the Dunlap SP Winter Sport 3D. I have a 2013 Premium Plus and need a set of winter tires/wheels I have a quote from my dealer for factory wheels, the same 10 spoke OEM wheels that came with the car, but as you can imagine they are fairly expensive. I also have a quote for the Dunlaps from Tire Rack Does Tire Rack offer a 18" wheel that would look good.
I had a less than stellar experience with my winter tire package for my 2012 A6.
Although I was most impressed with the Michelin Pilot Aplin PA3 rubber (they perform excellent in the snow and wet), I had continual issues with the balance. The Michelins (245/45/18) were applied to ASA GT5s.
The Tire Warehouse, Inc., in Queensbury, NY, installed the package in Nov. 2011. Over the next few months, they repeatedly (and unsuccessfully) tried to properly balance the setup. Got close a few times, but never right on - there was always a shake at speed ( usually over 45 MPH). It somewhat reduced the exhuberance of driving this beast in inclement weather.
At the end of the season, they ordered metal rings that are supposed to be set inside the wheels, but I had already changed over to the summer package. We'll see if the rings make a difference later in November.
They also did not have Hunter Roadforce balancing, and I was wondering if that might help in some way. If they can't get it right the first time, I guess I'll try to find a RoadForce shop locally.
