2018 Audi 55TFSI jerky gearbox
Hello
Is it ok to drive with these errors? The dealer's appointment is in a week, but the car's gearbox is somehow jerking. Especially at low speeds. If you let off the gas and give it again, it comes back with a jerk. The mechatronics have been changed for 8000 km. Maybe the clutch is out?
OK Misfire Monitoring (Manufacturer specific)
OK Fuel System Monitoring (Manufacturer specific)
OK Comprehensive Component Monitoring (Manufacturer specific)
OK Catalyst Monitor (Manufacturer specific)
OK Oxygen Sensor Monitoring (Manufacturer specific)
OK Oxygen Sensor Heater Monitoring (Manufacturer specific)
OK EGR and/or VVT System Monitoring (Manufacturer specific)
Süsteem: Mootor, DKMB, DRYA, DPAA, DMTC, DMTA, DMGH, DMGA, DLZA, DLHC, DLHB, DLHA, DLGA, DKYA, DKUA, DKNA MT/AT TFSI (Diagnosis)
P056200 Supply voltage; voltage too low
Süsteem: Käigukast, Gearbox Diagnose
P085D00 Gear Shift Control Module "A" Performance
Süsteem: Turvasüsteemid, Airbag Diagnose
(Veakoode ei ole)
Süsteem: Pidur, ABS ABS/ESP/EPB
U112100 CAN-Bus Failure - No CAN-Message
C105700 Right front tire
Süsteem: Kliimaseade, Climate control Diagnose
U127E00 Left side vent motor
U127700 Recirculation flap motor
U125000 Fresh air blower, front
U126500 Left temperature flap positioning motor
U126F00 Left rear temperature door motor
U127500 Defroster flap motor
U128A00 Right footwell flap motor
B10CD00 Function reduced by energy management
U128000 Right side vent motor
U127100 Right rear temperature door motor
U128800 Left footwell flap motor
U126700 Right temperature flap positioning motor
U128600 Right center vent motor
B10D122 Left B-pillar/footwell shut-off flap motor
U128400 Left center vent motor
U125E00 Rear right air distribution servomotor
U125C00 Rear left air distribution servomotor
U127300 Fresh air door motor
Süsteem: Näidikud, Instrument Diagnose
(Veakoode ei ole)
Süsteem: Multifunktsioon, Door electronics Driver´s side
(Veakoode ei ole)
Süsteem: Multifunktsioon, Headlight system Light control right 2
(Veakoode ei ole)
Süsteem: Multifunktsioon, Headlight system Light control left 2
(Veakoode ei ole)
Süsteem: Multifunktsioon, Headlight system Headlight control
Süsteem: Multifunktsioon, Gateway Diagnostic for data-bus
U140B00 Energy management active
U010100 Lost communication with TCM
Süsteem: Multifunktsioon, Central electronics Diagnose
Süsteem: Multifunktsioon, Comfort system central control module Diagnose
B1468F0 Return message regarding driver door closing condition
B1469F0 Return message regarding passenger door closing condition
B1800F0 Return message for driver side rear door closing condition
U115200 Rear lid opener control module
B147A18 Remote control key 2
Süsteem: Multifunktsioon, Battery Charger 1 For Mobile Devices Diagnose
(Veakoode ei ole)
Süsteem: Multifunktsioon, Infotainment Information electronics 1
(Veakoode ei ole)
Süsteem: Multifunktsioon, Chassis Control Air Suspension
C200700 Rear axle steering control module
Süsteem: Multifunktsioon, Infotainment Sound system
(Veakoode ei ole)
Süsteem: Multifunktsioon, Seat adjustment Seat adjustment driver side
(Veakoode ei ole)
Süsteem: Multifunktsioon, Door electronics Rear door, passenger side
(Veakoode ei ole)
Süsteem: Multifunktsioon, Door electronics Passenger side
(Veakoode ei ole)
Süsteem: Multifunktsioon, Steering Rear Axle Steering
0000E0 Unknown fault code
Süsteem: Multifunktsioon, Steering Steering assistance
(Veakoode ei ole)
Süsteem: Multifunktsioon, Door electronics Rear door, driver side
(Veakoode ei ole)
Süsteem: Elektrisoiduk, EBCA Electrical motor
0012CE Unknown fault code
Süsteem: Elektrisoiduk, Battery Management 2 Diagnose
(Veakoode ei ole)
Süsteem: Elektrisoiduk, DC/DC Converter Control Module Diagnose
(Veakoode ei ole)
Süsteem: Rehvirohud, Süsteeme ei leitud
Süsteem: Juhiabi süsteemid, Laser for distance regulation Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Control Unit Lane Change Assistant 2 Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Camera module, front Diagnose
B127F04 Right environmental camera
B127E04 Left environmental camera
B107BF0 Rear parking aid sensor
C12B002 Left peripheral camera, video wiring
B127D04 Rear environmental camera
B200FF9 Internal malfunction
B127F54 Right environmental camera
C12B102 Right peripheral camera, video wiring
C12AE02 Front peripheral camera, video wiring
B127C04 Front environmental camera
B13B901 Video wire for information electronics 1
C12AF02 Rear peripheral camera, video wiring
C12D8F0 Intersection assistant
U112300 Databus error value received
B2F0800 Development code 8
B200FFA Internal malfunction
Süsteem: Juhiabi süsteemid, Night vision control unit Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Distance controller Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Front Corner Radar 1 Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Front Corner Radar 2 Diagnose
(Veakoode ei ole)
Süsteem: Juhiabi süsteemid, Parking assistance Diagnose
Süsteem: Juhiabi süsteemid, Lane-change assist Diagnose
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
(Veakoode ei ole)
RobieTee
06-20-2024 09:23 AM
mikeagueros@gmail.com
Q5/SQ5 MKI (8R) Discussion
04-21-2024 01:43 PM
aky1988
11-13-2023 07:14 AM
Motowey
06-30-2020 05:14 AM
