A6 C8 auto hill hold button
Hi guys,
has anyone been able to retrofit the auto hill hold button. I hooked everything up according to the instructions but the button lights up when pressed then turns right off.
what am I missing?
what am I missing?
The auto hold button came with a kit that had a code box that I plugged into the OBD port to code everything.
I actually don’t think the box code the car correctly.
do you know how to code this particular feature?
Yes,
I had the hood open. When I plugged the coding tool into the OBD port, the box is supposed to light up green until the coding is completed. The green light started flashing then is turned off. The green light was never solid green as it was supposed to be when the coding was executed.
Hey guys, I took my 2019 A6 c8 to Audi and they told me I can’t do a retrofit for the Auto Hill Hold button.
does anyone know if that is true?
also has anyone done a heated steering wheel retrofit?
I had NGP do the installation for me, along with the Auto Park. Auto Park works fine but the Auto Hold is not. Might be a wrong pin connection as the programming looked okay.
They will work on it until it "Holds" as normal.
2020 Audi A6 Prestige 55 TFSI
DadAudi (03-20-2023)
