Can i disable the headlight washers?
When I use the washer fluid to clean my windhsield at night, the stupid headlight washers darken my lighting so bad that I get a little nervous. Can i disable the headlight washers?
whynotme (10-15-2023)
You do not need to disable anything. The headlight washing system is triggered about 2 seconds after pulling on the stalk. Just make sure you pull the stalk for no longer than 2 seconds if you do not want the headlights to be washed as well. Repeat the process a few more times if the windshield needs more cleaning.
ThomasWShea (10-17-2023)
There is a setting or something I am missing or a coding changed that may have happened between the 2020 I own and whatever updated versions some of you have.
Anyone have any other thoughts?
I thought this was the case for my car, as when my wife drives it seemed like that was the behavior from the passenger seat. However when I try this myself I always get a headlight spray (usually first), then a wind screen spray. I just tried again with a quick pull and got just a headlight spray...
