When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Because OBD11 is not capable of activating the sport layouts on the gen2 cockpits (a6,a7,a8,q3,q8...after 2018), only gen1 (a4,a5,q5,q7 until 2019). The Gen1 cockpit is just via hex eeprom edit which obd11 can do.
Reason being, the gen2 virtual cockpit needs to be flashed with a modified firmware (takes around 15min) and then updated again to newer firmware (also takes around 15min).
Only then the required adaptations are unlocked to activate the 3 layouts and only this step can be performed by any coding tool (obd11, vcp, vcds, odis, launch...).
So no coding device will support this as the flash happens via SD card or USB drive. Bluetooth would result in a big failure.
As said above, i can assist remotely for this.
Hey jasa004 I understood that's procedure is not allowed to gen2 cockpits. If I'm wrong just let me know. If I understood correctly the procedure will install a modified firmware that will change gen2 cockpit as a gen1 cockpit, correct?
With the procedure, we install a modified firmware twice. Then we enable stuff via a coding tool (obd11, vcds,vcp, odis...).
- 3 sport layouts
- RS Monitor in radio menu
- G-Meter in cockpit and radio menu
Hello @jasa004 ,
sorry if I ask again and again the same question but I want to be sure before doing something that I cannot recover.
I understood the procedure is allowed also for gen2 cockpits and my dashbors si:
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 794 D HW: 4K0 920 794 D
Component: FHybRDW------ H24 0058
Do you confirm I can update the firmware twice and it will work also with my MIB3??? My A6 is a my21 with last firmware P3853.
Thanks and sorry again if I ask again.
Hello @jasa004 ,
If your MMI is MIB3 then you have a different generation of cockpit. Not possible with this method. Currently no remote options for your vc.
If you have a 2021MY with Gen2 VC (has the S layout as one of the options); do you know how I can enable the oil temp / boost at the bottom of the display ?
A 2021 car has MIB-3, so it can't be done as yet - see jasa004's posts two posts above
Not sure about sports layout but can the additional views be enabled on Virtual cockpit basic ?
The additional views that are available on "Virtual cockpit plus" on Audi Q3 technik?
If i remember correctly, hardware and software dont support it. You can send me the version or part number and ill check. Holding the leftmost button on the steering wheel should open the version info menu in cockpit.
