[255/35/18] vs [235/40/18] vs [245/40/18]
For the first get 255/35's. For the second get 245/40's, and for the latter get 235/40's.
The sport wheels on the 4.2 have a 45 offset. You will rub with a 31 offset and 255 tires. Go with the 235, they should fit. 245/40 is too tall. Also try the wheel and tire forum, Gary can also give you his thoughts.
Kuhmo MX and SO3's are wide - some Pirelli's and Yoko's are narrow...
You'll for sure need to remove the top fenderliner screw - and maybe heat up some of the fenderliner with a heatgun to adjust it a bit...
I ran 255/40/17's on the 4.2 Sport rims with the proKit - worked well once I got the above things done...
be great if you can find a shop that will let you test fit the fronts....rears almost always fit.
best of luck
best of luck
HIS4
05-08-2006 07:01 PM
SteveTTR01
11-16-2005 03:42 PM
Michael Benno
12
09-04-2003 01:27 PM
Peter Lemon Jello
02-13-2002 11:44 AM
