'01 A6 2.7T Oil Change
Picked up a well used 01 2.7T for my daughter a while back and it is due for an oil change. Is there anything particularly unusual or weird I need to keep an eye out for?
TIA
TIA
When you remove/install the oil filter do not tighten/loosen without holding housing you are threading it onto. There was a service bulletin a ways back that states something like "When changing the oil filter, the oil cooler may become twisted (loosened), causing a leak between the oil cooler and upper oil sump." So be tactful with your non oil filter hand and hold the oil cooler housing whilst twisting the filter off...
17 Oil loss from oil cooler
17 10 12
2019851/2
August 26, 2010
Supersedes Technical Service Bulletin Group 17 number 09-11 dated June 10, 2009 for reasons listed below.
Affected Vehicles
CONDITION
Oil loss from the oil cooler.
TECHNICAL BACKGROUND
PRODUCTION SOLUTION
Service
Replace the 0-ring.
Replace only the 0-ring. The oil cooler is operative.
WARRANTY
REQUIRED PARTS AND TOOLS
ADDITIONAL INFORMATION
All parts and service references provided in this TSB are subject to change and/or removal. Always check with your Parts Department and service manuals for the latest information.
Me too. All those years of S4 ownership i never knew.
Then again, i dont put on oil filters with breaker bars and locktite, which appears to be standard Audi dealer practice.
G
G
FWIW, I switched to 5W-40 euro formula in 2008 or so and it was ok but the cam chain tensioner on the driver's side started acting up six months ago…switched back to 15W-40 last oil change (still doing 8K…oil analysis says negligible wear metals!) and the tensioner quieted down..no rattle at startup. I know I'm going to have to get in there this spring, but for now, all is well.
fair disclosure…lifetime amsoil dealer.
17 10 12
2019851/2
August 26, 2010
Affected Vehicles
CONDITION
PRODUCTION SOLUTION
Service
Replace the 0-ring.
WARRANTY
17 10 12
2019851/2
August 26, 2010
Affected Vehicles
CONDITION
PRODUCTION SOLUTION
Service
Replace the 0-ring.
WARRANTY
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
