16" wineglass wheels dont fit after replacing rotors and pads..
#11
on a 02 A6 2.7T with ATE calipers? I thought 3-5mm would work but now I am not so sure. I would hate to get the wrong size and have to return them. The calipers actually scraped 1/4 of the inside of the front wheels, so it would seem that 3mm would be enough.
#12
AudiWorld Expert
...anyone really knows what size spacers would be required for sure since most spacers are the result of upgrading wheels, and very few folks have upgraded to wineglass wheels.
The other thing you could do if your winter tires still have plenty of tread is to find a set of the OEM 2.7T wheels from 2000-2001 (flared 5-spoke wheels) which will ahve plently of caliper clearance. They are 16x7 ET45 wheels so you could reuse the tires you have. Those wheels are very inexpensive out on fleabay and other classifieds.
#13
how big a spacer i needed when my new wheels didn't fit, give yourself at least 2-3mm clearance between caliper and wheel - that being said i'd go with the 8mm spacer as that is the smallest hubcentric spacer (i believe) they make. if you went with a 5mm, which is minimally what you need (2mm to clear caliper + 2-3mm clearance), it's going to decrease the amount of bearing width on the hub as 5mm spacers aren't hubcentric (if you don't know what that means, hubcentric means the spacer has an integral hub that fits over the existing wheel hub, 5mm spacers are just a flat disc)...in that case, you'd need 36mm bolts
Greyhound Guy
Audi 100 / A6 (C4 Platform)
06-06-2006 07:09 AM
Jbone024
05-04-2003 09:16 PM
SpfldS4
04-22-2003 09:06 PM
