18x8 with 255/35/18 tires..
hi guys..
i spoke to gary at tirerack and he told me that an 18x8 wheel can not use a tire 255 size.
aren't there guys runnning 255/40/18 tires on 18x8 RS4 replica's?
thanks all!
thanks all!
AudiWorld Expert
I am basing this on the chart from the below linky:<ul><li><a href="https://forums.audiworld.com/a6/msgs/110254.phtml">https://forums.audiworld.com/a6/msgs/110254.phtml</a</li></ul>
it questions whether stock 17x8 sport wheels i have with 255/40/17 is too narrow...
i dont get it?
i know kgnast is running 255/40/18 on his 18x8 replica RS4 wheels...
i want to hear if he thinks its ok...
i dont get it?
AudiWorld Expert
<ul><li><a href="https://www.audiworld.com/model/a6/02/4_2_sedan.pdf">https://www.audiworld.com/model/a6/02/4_2_sedan.pdf</a</li></ul>
may have slightly different specs for an approved or recommended rim, but for the 255/40-17 or 255/35-18, approved rims are 8.5-10" wide for the tires I've checked. This is sensitive to tire profile, and the taller 255/45-18 does use 8.0-9.5" rims. When in doubt, check the tire manufacturer's web site for recomendations for the specific tire and size.
For maximum performance, you'd generally use the maximum width approved for the tire, and I have no idea why Audi often uses wheels narrower than the minimum specified by the tire manufacturers. At best, expect less than optimum wear and performance; at worst, early tire failures could result.
BTW: I retired after 34 years of involvement with the tire industry, and I'm glad to see my original A6 Tire Options post has hit 2400 views :-)
