1999 Audi A6 Automatic Transmission Issue
#11
Also the display screen is not readable (what a surprise lol) I heard that these Audi's come with a lifetime transmission fluid, i really don't know how true that statement may be but sounds like bull.
That code, P1857, is rather ambiguous, likely useless and probably irrelevant. The symptoms you describe is of a transmission running on low line pressure, often caused by low fluid, a clogged filter, or both. It may be all it needs is a simple fluid/filter change. When was this last done (if ever)?
That "stuck in 3rd gear" condition is "limp home mode". This is the default when the transmission is experiencing a problem of some sort. It is accompanied by the "PRND432" indicator at the bottom of the display screen being all lit up (assuming that the display screen is still readable at all).
#12
I've opened up ZF transmissions in Audis and VWs with up to 190,000 miles, still running the original fluid. My current car ('01 B5.5 Passat 4-Motion, an A4 in disguise) is one such car. It was used nearly entirely on the interstate, and was jumping in and out of gear, until I did the fluid/filter change. Now at 198,000 miles, it's one of the sweetest cars I've ever owned.
#13
#14
kingcezar1992
S6 (C7 Platform) Discussion
06-28-2019 05:29 PM
Chilostatic
10-09-2018 06:50 AM
Khalid
01-08-2018 02:39 AM
jaybro
11
04-28-2017 09:15 AM
