2.7T To 2.0T Coil Pack Conversion Kit
I found this on the ECS website. I was wondering if the 2.7t are known for having coil pack and ICM's issues. I did a search and didn't come up with anything. But i needed to know if this is a big problem.
The kit hints towards the coil packs and the ICM's are known problem areas.
Has anyone done this conversation? and is it a big enough problem that the conversation should be high priority.
Here's the ECS link:
Audi C5 A6 Quattro 2.7T ECS News Audi C5 A6 2.7T ECS 2.0T Coil Pack Conversion Kit - 002686ECSKT2 - 2.0T Coil Pack Conversion Kit - Anodized Black Plates With Black Coil Packs - ES#2730647
ADVICE is always Appreciated. .. Thank you
Yeah, I wouldn't worry about it. Coil packs are known to fail on almost all cars, and they do fail on Audi's fairly often - but you pop in a new coil pack and you're good to go. If you have the later style coil packs that look like what is shown in that kit - then they fail more often, in my experience, than the earlier coil packs.
My mom has a 2001 A6 with the early style, bolt-down coil packs and I think she just had one fail about a year ago and it was the first time it ever happened to her.
I have a 2004 A6 and I have the newer coil packs and in the past 5 years I've changed maybe 4-5 of them out. They just fail randomly and you get misfires.
So in my experience, the older coil packs failed once in about 13 years and cost about $90 for a new coil pack.
The newer coil packs failed about 5 times in 5+ years and cost about $25/coil pack.
I don't think it is that big a problem that I would upgrade anything...especially not for $400-500.
I recently did the conversion and I can tell you the car runs and idles like it has never done before. I've had some lingering idling issues for a long time, but I could never nail down the culprit. New coils, ICMs plugs etc and it would still idle rough from time to time. Now it is as smooth as butter with the same plugs I had in there.
I went the solder route vs. the kit, but that's because I'm a cheapo ;-) and knew my way around a soldering iron and electronics etc.
If you don't have an immediate issue I would not do it for the sake of doing it, but if one of the components die I would strongly suggest the mod vs. replacing expensive coils or ICMs.
My 2c
Cheers
Massboykie
ECS Tuning-Audi
09-17-2020 02:57 AM
ECS Tuning-Audi
11-12-2015 11:47 AM
ECS Tuning-Audi
11-20-2014 12:59 PM
ECS Tuning-Audi
Audi allroad
07-14-2014 05:54 AM
ECS Tuning-Audi
07-08-2014 08:20 AM
