2.7t with fault code 17887??
Doing a vag-com check the other day and this code popped up, I know it relates to the brake booster!
Ive done a check with vagcom using block 008, the test comes back as "system not ok" now im assuming there is a vacumn leak somewhere, but where?
I initially though it would be the jet suction pump, but from reading other posts it may seem my car doesnt have one with it been a late 2001 car? Is there or not?
If there is not what else could it be, what else do i need to replace?
The barkes are fine and car runs fine, can this fault cause any engine worries, as my understanding was this may create a vacumn leak from the manifold?
Help!
Help!
there are several jet suction pumps, one used on fuel system area one on the brake booster. check your accordian pipe. if you have a small swivel port on the bottom connected to a hose that leads to the break booster SJP. i removed mine as it cracked the port and just plugged it up, really a stupid thing to have on htese cars
LaguitasA4
A4 (B7 Platform) Discussion
09-25-2016 08:52 PM
mikebessxxx
06-17-2008 07:39 AM
PassatInTheWrks
30v V6 Discussion
01-08-2007 11:09 PM
