2.8 cam chain and tensioner replacement
#221
Sorry, the document for the fuel pump location is in a wiring diagram pdf too big to attach on audiworld...and I don't know how to make pdf's smaller...But it says it's position 4 from left to right on Micro Central Electric Panel and it shows a picture of this panel...it doesnt say where this panel is though...
#223
#224
Caution if/when removing the pump. For the A6, I had to be ~ < 1/4 tank. Otherwise when pump cover-seal removed, lots of gas leakage.
#225
Don't need to take pump out to check it.Just remove seat (if same location as the A6 pump), remove protective cover, disconnect connector, & put 12V across the pump circuit. Do not remove the pump, so no fuel vapors floating around. Checked mine by running ground circuit to a vehicle ground, & running a wire from battery + to the pump area. Touch the wire to the pump + circuit & if pump is good, you'll hear it run. If it doesn't run, bad pump.
I noticed on the spare pump I have, there are 2 wires brown(-) and green(+) should I be looking for the same colors on the connector?
What happens if I charge the wrong wires? Will it damage the pump?
#226
To get access to fuel pump, if the procedure is the same as A6, remove rear bench(bottom of rear seat), by lifting the front edge upwards then towards the front of car. Before that, Bentley says to disconnect battery because you'll have to unplug a side airbag connector(if equipped) so as to not deploy
There is also a connector for heated seats.
There are two round plastic covers. On A6 fuel pump is on passenger side. The other cover is for a fuel level sensor. The pump has a fuel level sensor next to it too.
#227
#228
I never had problems with the pump, I have no idea. I would search on Google or you tube. They might have basic pump testing. I know they have tutorials for removing the pump(which I wouldn't do unless I'm 110% sure it's the pump).
#229
ya I saw that on youtube, there is actually a video for a 2000 A8 which is quiet good, but I wanna test the pump first before having to do that.
#230
Hey guys I got a real problem here! The good news is the fuel pump is working when I charge it manually with the battery, gas pumps up to the fuel line but when o connect the connector back in and turn the key it does not respond. I think the issue is from the connector itself. So so far the fuel pump is functional, the fuel fuse is OK as well, but I cannot find the fuel relay!!!
Anybody know where the relay is located? Or what else could be the issue?
