2.8 with excessive carbon deposits...need advice
#11
It might be worth investigating whether Golden Lodge plugs
will fit and work. It is a copper based multi-electrode plug designed for cars that tend to foul easily (I don't have the exact specs, but it not quite like the Bosch plugs - besides the platinum). They are around $5 each.
If I recall correctly, the 25HL is the coolest, HL is medium, the 2HL is the warmest, and used in many V6 Alfas (among other cars) for the last 25 years. Anyway, I run 2HL inmy car and swap them out every 25/30K when I do the timing belt.
#13
Re: I've never had a plug stick (knocking on wood) but I like the Platinums...
I'm in Lexington Ky, but I'll withhold the name. I got a feeling there are some here that would accuse me of cruising the forums in order to pedal my wares. Not interested in that, I'm just a little hyper, gotta be doing something every waking minute. Ed
#15
Use MotorClean Internal Engine Cleaner
Kaleco's synthetic blinker fluid is also top-notch stuff.<ul><li><a href="http://www.kalecoauto.com/fluids.htm">MotorClean Internal Engine Cleaner</a></li></ul>
#17
Re: "The first time you take the aluminum threads out with that ol plug"
<center><img src="http://pictureposter.audiworld.com/1018/a8_plug_2.jpg"></center><p>BTDT, except it didn't take out the threads, the plug broke first. I guess that's a good thing, thinking about it.
See:
<a href="https://forums.audiworld.com/a8/msgs/24844.phtml">I am sooooo screwed. Suggestions welcomed.</a>
Followed by:
<a href="https://forums.audiworld.com/a8/msgs/25272.phtml">Success! (broken spark plug repair follow up)</a>
And I got an email, and then a call, for advice on this, from a guy with a 12V A4, in the last few days. In fact, I need to go check on that one, see how he did.
See:
Followed by:
A4audigirl
A4 (B7 Platform) Discussion
11-13-2017 06:57 AM
Summit
01-28-2000 06:39 AM
