2.8 Just replaced motor, need some help
#11
I have an update with more pictures and details. Hopefully I will be exposed for the Audi noob I am and have missed something simple but important.
Below are three pictures.
One shows the motor from the top and the main vacuum area. It looks correct to me, when compared to the vacuum diagram I found under the hood.
One shows the front of the motor. If you look to the right of the crank pulley there is something screwed into the front of the block like a sensor without a plug. Forgive my terminology but it looks like a nipple/spark plug. What is this? Surely this must be important.
One shows the drivers side fender area and a vacuum line that I think goes to the vacuum reservoir(although I cannot see it as the line goes back into the fenderwell. Is this indeed the reservoir?
Thanks to all those involved.
#12
Yes. Line should route behind the bank two cam sprocket then along the bank tow fuel rail to the vac solenoid area.
#13
As for the oil temp sensor, what do you call the piece that turns the nipple looking sensor into a plug I can connect the harness to.
Thanks again, I am trying to convey all of this mess in text and pictures as best I can and appreciate all the help from everyone.
#14
The wire end slides right onto the end of the sensor...from the side. Nothing fancy. The wire is probably floating around somewhere under the AC compressor near the oil pressure switch.
#15
From reading many posts the two sensors that might be the cause now are the cam and crank sensors correct?
#17
No it is factory old. I checked on Alldata, is it this sensor?
"Engine Coolant Temperature (ECT) Sensor -G62-"
Coolant Temperature Sensor/Switch (For Computer)
Coolant Temp Sensor
Right
Contact dealer for most current part and price information.
Order By Description.
078919529F $322.08 icon_note_blank.gif Notes
Left
078919529G $318.35 icon_note_blank.gif Notes
PS Why is a temp sensor so expensive? I also saw a temp sensor in the lower radiator hose, is this a 3rd temp sensor for the cooling system?
Coolant Temp Sensor
Right
Left
#18
I just checked those two part numbers and it looks like they are exhaust temp sensors??? Is Alldata wrong on the ECT part number?
Edit: I found the correct part and its 20.00 shipped: 059919501A
Is there a way to test the current sensor to verify it is bad or is it just common for them to fail?
#19
