2000 4.2A6Q Instrument cluster
OK, stealer wants $1200 plus to change out the instrument cluster. The pixels in the center are dim/out.
I can get it rebuilt at (link below) for $350.
How tough is it to remove/replace the cluster?
I understand the car cannot be driven because the immobilizer is in the cluster....do I need a VAG-COM tool to reinstall the cluster/immobilizer?<ul><li><a href="http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=282">http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=282</a</li></ul>
Sloop-been awhile since I've seen you 'round here. Here's the write-up, courtesy of
AudiSean. And yes, the Vag-Com is required as part of the process.
Hope all is well with you.<ul><li><a href="https://www.audiworld.com/tech/elec106.shtml">DIY Instrument Cluster replacement</a></li></ul>
May not need the VAG-COM...
Since they are rebuilding your cluster, and not just using it as a core and sending you another unit. Their webpage states that the mileage won't be affected, so it should be plug and play.
repost instrument cluster--I"m buying the display from .de
I'll let the board know how it works out.
About 165euro delivered registered mail to the US.
I asked how tough it was to install...they said it required some soldering. Ought to be interesting.<ul><li><a href="http://www.tachopix.de/nav.391/subnav.9430/language.en/">http://www.tachopix.de/nav.391/subnav.9430/language.en/</a</li></ul>
DrewB612
09-01-2006 03:32 AM
