2000 A6 2.7t starting problem
I came out to start my car about 2 hours after driving it, and it wouldn't start. Just kept cranking over. Sounded to me like it's not getting any fuel. I let it sit for a day, tried again and it started right up! I let it run for 10 minutes or so, turned it off, and it started right back up again. So I started to drive home, and it just died on me. I pulled over, and it started up and immediately died. I waited a bit, and it started again, but died. I had it towed home, and after running diags, there are no codes thrown. The fuel pump seems fine, replaced filter. I then replaced the 2 ignition modules on the top of the airbox, thinking these might have something to do with it since if they go bad, there is no code related to them, however the same problem is happening. Does anyone have any ideas?
So my 2 cents, Check ignition switch, fuel pump, and fuel pump relay.
I agree Dano that it sounds like a bad fuel pump.
Happened to my exroommate's fuel injected van motor while driving through Alabama/Mississippi.
Had to get towed to a station, dumped the gas/let the water go to bottom, skim the top, new fuel filter with a can/bottle of HEET....this in the middle of summer! Alcohol/HEET probably doesn't do vapor lock issues any good, but better than water!
Could well be CTS if it tells the engine ECU the engine is cold when it's actually warm/hot and overfuels the engine/floods it. One way to check the next time it doesn't start is to pull one spark plug and see if it's wet.
Brian Dubois
03-29-2019 03:23 PM
Loke Sølvåre
New Member Welcome Area
05-13-2018 05:05 AM
