2000, a6, quatro, 2.7t
#11
Well, you need to get a chip that has rear 02 delete... removing the cats will drastically lower the after car exhaust temp and tell the ecu to add more fuel to raise cat temps. Maybe this is causing the misfires and overboost from an over rich condition. Unless you specified to the chip supplier that you were not using rear 02's already.Not usre if this is your problem, but it sounds like the first step to investigate.
#12
the rear o2 does not actively control the fueling loop. and if you wanted to raise the cat temps you would lean the mixture out to up the egts........ really dude 15 years of race car building?
slobodan, please do not follow this line of thought in figuring out whats wrong with your car. there are so many things fundamentally wrong with this post
#13
OP
you have a ko4 on a ko3 chip, you have not told us the boost levels you ar running or what upgraded fueling you have. you can not simply bolt on ko4s and call it a day. you need to make some tweaks to get it to run. and running a ko4 at the bost levels your chipped ko3 was at, without increase fueling capacity (think injectors/fuel pump) you can cause some serious issues.
also have you checked your spark plugs? i would be there is damage to the electrodes
my advice is check spark plugs (report back to us with pics) and put a boost gauge on the car and go for a drive, that way you can tell us what the boost level is, and what its spiking to
#14
you really do show your ignorance with these cars
Thanks
#15
OP
Thank you
ip4me
Performance and Tuning
9
03-02-2005 07:46 AM
bud4ya
44
04-02-2004 01:20 PM
