2001 4.2 - 235 45/17 vs. 245 45/17
#11
If you install a larger diameter tire, then yes, the contact patch should be higher.
If you only install a wider tire, then it doesn't automatically translate to a wider contact patch.
Because the mass of the vehicle remains constant, the wider tire will have a wider patch across but a shorter one length wise, no? At the end, it ought to improve lateral road holding ability, but will it necessarily help reduce wheel spin?
It seems that tire pressure wil have a bigger difference on the contact patch then going from, say, 225 to 245 wide tire.
I remember drag racing and reducing rear wheel pressure to about 22 psi to help with the take off.
An even bigger difference will be made by the rubber compound in the tire.
#13
You're right for the most part...here's an interesting link:
http://www.performancesimulations.co...on-tires-1.htm
F=PA is too simplistic. Like the movie, it's complicated.
Hibiscus Red S4
01-03-2005 07:03 PM
dlubin
9
05-18-2003 06:20 AM
FrankM2.7
Wheels & Tires Discussion
04-21-2002 12:35 PM
PakiA4
03-27-2002 11:26 AM
