2001 A6 2.7T high beam problem
Hi- Both high beams are out on 2001 A6 but all other lights ,signals, etc work fine. High beams work fine when pulling back on the momentary lever so bulbs and fuses are good. Does this suggest the dash switch, the stalk switch , or is there a relay that could be bad? Thanks, Jim.
If you have HID bi-xenons the inner two lights are halogen but do not come on with high beam.
They only light with the pullback.
Did they ever come on or are you just noticing it now?
The same operation happens momentarily when the dimmer switch is pulled back toward the driver for flash-to-pass.
My bixenon shutters are powered off of the halogen high beam bulb circuit, so that seems reasonable, and mine behave in the same fashion. The high beams and shutters would have to have different power sources for that not to be the case.
Then the simplest and most probable answer is the stalk switch needs to be replaced.
It's the signal device for the relay that powers the high beam. Pulling the stalk works the high beam, pushing it doesn't. Therefore it's the switch.
Dunno. My 02 S6 has bixenon HID low/high beams and the high beam halogens don't switch on (USA model) with the stalk pushed forward. They only switch with the stalk pulled back.
newman_buddy
12-17-2002 12:52 PM
Cyan S4
10-23-2001 07:46 AM
