2001 A6 4.2 -check engine
I had P0491, as it turned out it was the combination valve. My mech and I checked both just to be sure, and found that both could not hold vacuum. Start there, hope that helps.
Thats calling out ur secondary air injection system, both banks dont seem to be getting enough air flow. The air injection pump is only activated once u start up and only when the coolant temp is low, it sends air into the cats for faster and cold startups. I'd find the air injection pump, turn on your car then check to see if u can tell if the pump is working or not...if not, i'd check the fuse, mine was under my hood and next the the battery area. I have the same codes and i think my pump is bad
Nichole77
12
04-04-2016 01:16 AM
audilover917
Audi 100 / A6 (C4 Platform)
05-22-2007 09:29 PM
