2001 A6 4.2L transmission problem...
I bought a 2001 A6 with 4.2L (80 K miles). the transmission goes into limp mode with P0730 code (incorrect gear ratio). The dealer (useless) scanned it and they think its internal issue such as the clutch, shaft or drum. I am not sure which way to go about this either rebuilding the tranny or replacing it with a used one. cost will be the same but I am not too confident with the rebuilders. Does anyone know of a common problem with the transmissions so I would may have the same issue with a used one? Any commets would be appreciated. Thanks
Check the passenger side back seat floor carpet for water (under front passenger side seat) Some A6's have issues w water drainage/leaking and the tranny control unit us under the seatunder the floor carpet and can actualy get submerged in water causing malfuction and eventual failure.
I pulled the carpet up on the passenger side and the module was completely submerged. I dried it out and baked it in the oven at 150 deg for a couple of hours to completely dry it out. Works fine now.
Murph, if ya can not figure where and how to stop the water intrusion, you will want to drill
a small hole in the body from inside underneath the tranny CU to let water drain out. if it was flooded it WILL flood again. I checked air cabin filter housing gasket (one between filter housing and body)for leaks, repair w auto silicon caulk type sealer,check and clear sun-roof drains,cheak and clear water drains underneath battery....
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
harrygrimes
07-08-2008 05:33 PM
A62001
05-28-2003 04:00 AM
