2001 AUDI A6 2.8L (FWD) TROUBLE CODES
Hi, I need some help. I have a few trouble codes and I would like some expert advice on what might the problem be.
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
1) 18057.P1649
2) 16502.P0118
3) 16514.P0130
4) 16825.P0441
You might try searching for codes by entering only the part from "P" on. So P1649 yields an ABS code, P0118 is a coolant temp sensor, P0130 is an O2 sensor and P0441 is an evap system purge flow. If you add Audi to the front of the search string you also get pretty good results especially if you drill down to an Audi link. So audi p1649 yields ABS problem and an Audi solution.
Ryanl2488
09-04-2012 04:07 PM
oillady
03-08-2009 04:06 PM
