2001 Audi A6 shift knob help please
So i read a past thread on how to fix tiptronic if the magnets fell off. so i followed the directions to remove my shifter ****. replaced the magnet that fell off. But now when i put the shifter **** back on the button dosent work. Acts as if a spring or something is broken, im not sure. the button just pushes in and stays. I can pull in back out, but it dosent sprig in and out like it should. Did I somehow put it back on wrong. Or did i break it. Can someone please help me. Also is there a way I can stil shift the car into gears like this. Help me.
So just to be sure. When you did it, you moved the shifter down to the 3 position, pulled the button out and then pulled the **** off? Then when you installed it you had it in 3 and pull the button out and push on? Should be fine. I have had them when the button actually comes out of the **** and its tricky to get it seated back in right.
Uhhh If you pulled it off with it in park, you just destroyed the shifter assembly. See the yellow/clear plastic post sticking up, if you pull on that it should move through the gears. It should have a square hole in it that the **** grabs and pulls up. Its probably now broken off. You should have read how to do it before yanking it off lol.
your talking about the white thing that come out of the shifter that when i pull up still allows me to change gears with out the leather **** that goes on top right?
