2001 C5 2.7t Random Loss of power when under pressure. Here is the Vagcom Codes
I am Losing power in 3rd gear at about 3500rpm only when I am stepping on it. I also lose power random whenever i step on it. Here are the vagcom codes
5 Faults Found:
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-00 - Open or Short to Plus
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-00 - Efficiency Below Threshold
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
16487 - Mass Air Flow Sensor (G70)
P0103 - 35-10 - Signal too High - Intermittent
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
I have a apr stealth catback and a awe b5 s4 downpipe cut and modified for my C5. I also have a b5 vast performance intake with heat shield. Giac chip
5 Faults Found:
EGT sensor failure like the code shows will put the ECU into limp mode, making the mixture rich and limiting boost. This is a common failure - the solder joints inside the EGT electronics box come loose or short out. You can open the box up and re-solder the connections, or (what most people do) just replace the unit.
Jim
Jim
Jim
Jim
PMrider
05-27-2008 06:47 PM
Bender11
05-06-2008 08:41 AM
N9909E
09-14-2007 06:37 PM
Gldnrkt(GT3076R)
09-11-2006 04:30 AM
Kapoosh1
12
10-16-2005 06:24 PM
