2003 A6 3.0
Old 03-16-2013, 12:26 PM
  #31
SloopJohnB@mac.com's Avatar
Originally Posted by cbrown9064
Well Gents, The 2003 A6 3.0 is toast. See attached pics. Middle cylinder on passenger side exhaust cam is shot. I could not get a pic of the lifter, but looks like it has a hole worn in the top of it?
Thoughts? The only fix is a rebuilt head right? My understanding is you cannot put a cam and new lifter in it. Or is that not correct?
I was hoping this was not the case. Arrgghhh! Oh, I don't see any cam chains in this pic.
I don't see why you cannot put a new cam and new lifterS in? A wiped cam just leaves the valve more or less closed....a new cam and followers should fix the problem. You need new followers because the followers need to wear in to the new cam.
And yep...both cams driven by timing belt.
  #32
jcman's Avatar
Well that sucks big time Chris, yep it always seems to be #3 on that side when it's been posted here.
You can just replace the cam and tappet with out pulling the head as I've read actually on this forum if I recall, not an easy job though.
I've helped on a few TB's with these engines and have not seen this cam wear you have, never saw a chain either on them too.
Old 03-16-2013, 12:30 PM
  #33
jcman's Avatar
Here's part of what your looking at on this job.
File Type: pdf
Old 03-16-2013, 12:45 PM
  #34
Huskerbob's Avatar
Chris, read the repair description that jcman attached below and then make your decision. It looks like you need some special tools and some really special goop to seal the cam frame to the head. And as a bonus you get to do all this work leaning over with the head at a slant. I guess you could pull the head and work on the bench but even then you need to round up the tools required. Maybe you can make do without them. Not sure.
Good luck.
Old 03-16-2013, 02:25 PM
  #35
jcman's Avatar
Found this from a member with a similar problem.
Linky https://www.audiworld.com/forums/sho....php?t=2820572
Old 03-16-2013, 02:47 PM
  #36
jcman's Avatar
Default From the golden vault of the past
I present you with this one that has some good info on the timing aspects relative to a tb service without a new belt like in your case.
https://www.audiworld.com/forums/sho....php?t=2839759
Old 03-16-2013, 03:13 PM
  #37
cbrown9064's Avatar
Thanks JCMAN! If you had the special tools, it would not be overly complicated, but very time consuming. I am wondering what a cam and followers are in $. Going to try and do some research now. Tried calling the nearest dealer today, but they did not return call. Will try again on Monday.
Old 03-16-2013, 04:02 PM
  #38
jcman's Avatar
Default Your welcome!
Chris real important tools you would need to do this job is a crank lock pin, cam locks and the cam socket, and alot of time.
Report back, I'll be here as always.
Old 03-16-2013, 04:54 PM
  #39
2.7Lturbo's Avatar
sorry about your loss, but this is all to common in 3L land... a new cam will prob set you back 1K... but worse, dont you need a new head as the caps are ground for that specific head/cam combo :/
Old 03-16-2013, 05:55 PM
  #40
jcman's Avatar
Default Oh man the timing on this just follows you
Your a real sweet heart Turbo, now excuse me while I crawl back in my corner returning to sipping on some real good ale and taking in all of the post drama today. He He, Dang It!
Quick Reply: 2003 A6 3.0
