2004 A6 2.7T Won't Start
Drove to several different places shutting off the car each time. Started no problem without any indications of problems. On my last stop the car would not start at all. No click, no turnover. The battery is only a month old. I measured 12.62V on the battery. Called the tow truck and they could not jump it either with their jump box. Had the car towed home now it sits in the driveway.
Any ideas what to check? All the normal dashboard lights come on, lights, radio, etc work. The alarm will arm/disarm without a problem. I suspect the immoblizer may be the issue but don't know how to check. The starter sounded fine each start before so I don't see how it could just die.
The Immobilizer light on the dash panel goes out 3 seconds after the key is put in the ignition. This is the proper operation according to the Bentley manual. So it doesn't look like the alarm systems is causing the trouble.
Unfortunately I don't have a scan tool to use.
Ran into the same problem, unfortunately it took replacing a ton of other stuff in order to figure out it was the RPM sensor, including a new fuel pump(which I didn't need)
Do you mean the engine speed sensor? That's located under the coolant resevior tank.
I talked with the Audi dealership service manager, who was quite helpful. He seems to think the ignition switch itself is dead. They can't get to my car until Monday so I have this weekend to troubleshoot it. Although I won't be replacing the ignition switch myself.
The service manager was an Audi technician for 8 years previously so he was knowledgely. Several things he asked about I can list here:
1. All the dash lights do come on as normal. Most go out when cranking. My car seems to do this just fine. Only the ECM, Battery, and seatbelt light stay on during cranking and he stated this is normal.
2. The gear selector display shows on the dash panel and follows the gear selection movements. My car does show the selector display and illuminates the correct gear selection when I make a gear change.
3. Check fuses under the E-box. Have yet to do this but will check it out. This is a long shot and most likely not the problem.
4. The Engine Speed Sensor nor camshaft sensors should not stop the car from cranking. According to the service manager these sensors may stop the car from turning over but not from cranking.
I also tried my other key fob and that did not crank the car either.
I tried the VAGCOM locater website for someone close by (next town over) but their email address was no good.
Using the Bentley Manual Wiring Diagrams. I checked and reseated the Starter Interlock Relay, J207, in the 13-fold relay panel under the driver side dashboard. The car then fired right up.
No glaring codes were set other than the high beam open circuit
Thursday,17,December,2009,14:54:02:38534
VCDS Version: Release 908.1
Data version: 20091018
Address 01: Engine Labels: 078-907-551-AZA.lbl
Control Module Part Number: 4Z7 907 551 AA
Component and/or Version: 2.7L V6/5VT G 0010
Software Coding: 07752
Work Shop Code: WSC 02334
Additional Info: WAUCD54B14N AUZ7Z0D2614115
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: DTCs cleared
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Control Module Part Number: 4B0 962 258 M
Component and/or Version: Central Lock/Alarm D38
Software Coding: 15885
5 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
Address 35: DTCs cleared
Address 02: Auto Trans Labels: 01V-927-156.lbl
Control Module Part Number: 4B0 927 156 EE
Component and/or Version: AG5 01V 2.7l5VT USA 2223
Software Coding: 01002
1 Fault Found:
18161 - Tiptronic Switch (F189): Implausible Signal
P1753 - 35-10 - - - Intermittent
Address 02: DTCs cleared
VCDS Release 908.1: SRI Reset
Control Module Part Number: 4B0 920 983 F Labels: 4B0-920-xxx-17.lbl
Component:KOMBI+WEGFAHRS. VDO D16, Coding:16264
Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 ---
40 Mileage since Service miles x100 183 ---
41 Time since Service Days 796 ---
42 Min Mileage to Service miles x1000 10 ---
43 Max Mileage to Service miles x1000 9 ---
44 Max Time to Service Days 365 ---
45 Oil Quality 1 ---
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUCD54B14N
Part No: 4Z7 907 551 AA
Component: 2.7L V6/5VT G 0010
Coding: 07752
Shop #: WSC 02334
No fault code found.
Readiness: 0110 1101
Part No: 4B0 927 156 EE
Component: AG5 01V 2.7l5VT USA 2223
Coding: 01002
Shop #: WSC 02334
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 06397
Shop #: WSC 02334
Address 15: Airbags Labels: None
Part No: 4B0 959 655 AB
Component: Airbag 8.4EP 1001
Coding: 0000707
Shop #: WSC 02334 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 F
Component: KOMBI+WEGFAHRS. VDO D16
Coding: 16264
Shop #: WSC 01117
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02334
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02334
1 Fault Found:
01533 - Terminal 56 (High Beams)
36-10 - Open Circuit - Intermittent
Address 56: Radio Labels: None
Part No: 4B0 035 195 N
Component: symphony II NP2 0410
Coding: 00205
Shop #: WSC 66560
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 USA D08
Coding: 01126
Shop #: WSC 02334
End ---------------------------------------------------------------------
