245/45R17 on 17x8 rims
I plan to. It will fit. ~2.8% circ over stock
And it has the great benfit of carrying more sidewall and significantly more load rating capacity, so those of us int he northeast might bend fewer rims.
I run 225/55-16 in the winter - even larger with no problem. In fact, I like it. (S6 avant)
Grant
Grant
Re: 245/45R17 on 17x8 rims
Mine are 255/40/17 and I have a 2.8 2001 they dont ever rub, I get great stability on the freeway and the noise level is low (Conti-sport contact)
Overall im pretty happy with the performance and looks. So you should be OK with your set up, no worries mate.
<img src="http://macdok.com/ebay_images/audi/rear.jpg">
<img src="http://macdok.com/ebay_images/audi/grass.jpg">
<img src="http://macdok.com/ebay_images/audi/side.jpg">
<img src="http://macdok.com/ebay_images/audi/front.jpg">
<img src="http://macdok.com/ebay_images/audi/closeup.jpg">
Re: I am running 235 on 17X8
Thanks for the input so far. The issue is that the 245/45R17 is actually 0.6" larger in diameter than the stock 255/40R17 on my 2000 A6 4.2, so I was wondering if anyone is running this setup without problems/rub.
Re: I plan to. It will fit. ~2.8% circ over stock
Good to hear...do you know if the S6 Avant is comparable to the a 2000 A6 4.2 in terms of clearance for the wheels?
From your earlier post, I would guess that you don't have the sport suspension...
so you should be fine. I've seen posters here say they've used 255/40/18 wthout having rubbing issues. That's an even taller, wider tire than you're contemplating.
Koz.
Koz.
I run 255/45's at times
On my 17 x 8's on a 4.2. They match the outer diameter of the 255/40 18's I run with RS6 OEM wheels and RS6 stock tire size. RS6 wheels get run in summers and the 17's get run with either all seasons or snows for winter. Both fill out the wheel wells more than the regular 4.2 size--a beefier look overall, and a little more sidewall to absorb winter road problems. It's only a few percent off in the running diameter, and actually gets the speedo just about dead on (speedo's most commonly read a bit high). Performance still good either way; a bit heavier in the larger size; bit smoother ride of course, though handling is still quite good.
