3.0 V6 intake actuators easily removable?
My one month old thermostat has developed a leak so I will replacing it again. Are the intake actuators easily removable (in order to create space to remove t-stat)? I see two torx bolts holding it in, it is simply remove? Or are there butterfly valves...etc which are part of the assembly?
Right, the t-stat is in front but under the intake actuators.
The actuators
![](http://img189.imageshack.us/img189/6254/img07077593707.jpg)
And the t-stat to the left and underneath
![](http://img221.imageshack.us/img221/8489/img07087598008.jpg)
Question is if the actuators are removed by the two bolts and whether the assembly is just what is showing or has more parts in the intake manifold?
The actuators
I can't remember exactly but I know I had them out when replaced the thermostat. You have to unhook the little linkages I believe but whole assembly will pull out, just wiggle/twist/wiggle.
UrS4boy
Audi Original "S" Cars
12-06-2013 10:34 PM
computrtutr
08-23-2008 04:38 PM
