4.2 cam timing
4.2 cam timing
Had a cam timing adjuster go bad, left head. Installed new one. Reinstalled the timing belt per Bentley, this belt only has 8000 miles on it, I did it last July. Now its running like poop, throwing a p0341, right head cam sensor and a bunch of misfires. Swapped the Halls and it is still throwing a p0341, so it has to do with the RIGHT head. The bently says that there are 16 links on the right head between the timing marks and only 15 links on the left head, left is the one I worked on. Is this correct?
also
I rechecked the belt and found that the flat side on the cam where the diamond shaped washer with the holes in it for the cam alignment tool is no longer flat. Don't know how this happend, but I guess that I was not paying attention after I poped off the cam sprocket and did not have the retaining bolt tight enough when I snugged it down, anyway if F'ed up sooooo the cam tool is almost useless to get the left cams back in time. I can get them close, but not perfect.
I noticed that the timing marks on the left head cams do line ip with the arrows on the caps, but..... the engine is not on tdc when they are lined up.
My question is, with the crank at TDC, I have the locking tool in place, do the cam timing marks line up with the arrows on the caps or are they offset? Any of you 4.2 guys have your valve cover off for a belt that could look for me.
I would assume that the cams timing marks and the crank TDC position should match, but the bentley manual really does not say, that I could find.
also
850.00 for a cam!
The cam is not damaged just the flat on the end. The flat has nothing to do with the function of the cam, just the setting of the timing between the two heads. IF the timing marks are supposed to line up on the cams when the engine is at TDC, I can set the cams in the correct position without the tool.
I don't believe that
The tool is a convience so that you don't have to remove the valve covers. If the cam timing mark are also lined up when the engine is TDC, then it will be no problem. I will just have to hold the cam with another method, like the 3.0.
