5 monitors not ready. CA emissions coming up.
Old 03-17-2015, 02:30 PM
  #11
the_duke's Avatar
SAI is temperature activated. If ambient temp is high enough it won't run.
Old 03-17-2015, 03:39 PM
  #12
jcman's Avatar
Default More than Ambient temps
When the engine is at idle "only" in closed loop and cold the SAI system is activated until the pre-cat O2 sensors see normal levels, this can happen way before the engine is at operating temperature by the CTS.
This all started with the MPI control units MMS 400/410/411 beginning in 1996 when Audi ditched EGR's, since then our Motronic ME 7 ecm carries the same order with the SAI.
Old 03-17-2015, 07:08 PM
  #13
audi_nicoya209's Avatar
what is the function of the N112 valve and the N249 (if the 2.8 atq has one)
Old 03-18-2015, 04:56 AM
  #14
jcman's Avatar
The N112 is a solenoid type valve that when energized allows vacuum to actuate "open" the combi-valves, part of the SAI system.
The N249 is a solenoid type valve that is used to actuate the DV "Diverter Valve" on 2.7 turbo engines.
Old 03-18-2015, 05:34 AM
  #15
Airbag's Avatar
the solonoid and vacuum lines are easy to check and are right up top. the vacuum lines sit on top of the intake manifold area and are prone to rotting. check those first.
Old 03-18-2015, 07:13 AM
  #16
I'll definitely check all the lines because my pump is definitely running i can hear it. By any chance what size hose is the hose that comes out of the combi valves and then all the lines in general?
Old 03-26-2015, 07:54 PM
  #17
Default *UPDATE*
So I replaced all my vacuum lines and got rid of the check engine light and finally passed my emissions inspection with flying colors this afternoon. Thank you to everyone who contributed to this thread it is much appreciated
Old 03-27-2015, 01:17 PM
  #18
jcman's Avatar
Excellent!
I'm going to crack open a cold one this evening and raise it high over your victory! Plus it's Friday.
Old 03-28-2015, 07:41 PM
  #19
Excellent!
haha thanks dude 👍
spoon2000
04-01-2011 01:26 PM
Roberto7
12-07-2007 09:26 AM
Preatorian
12v V6 Discussion
09-24-2007 03:05 PM
wolfpack5
04-09-2006 05:01 AM
@udi4.qwick
04-03-2006 04:25 AM
Quick Reply: 5 monitors not ready. CA emissions coming up.
