6 Speed Transmission (Code GBE) with APB 2.7 Engine
Has anyone married the 6 speed (code GBE) tranny to an APB engine? I got 2000 A6 2.7, local shop has a VERY nice low mileage tranny from an A4 with 3.0 engine (not sure the code) for a very very good price. My original 6 speed transmission code is EDU. Is it possible?
I took physical measurements and the length as well as the width and the length of the shaft as far as the diameter of the shaft are exactly the same. I'd imagine the gear ratios are different, if so how would it affect the performance if it IS in fact possible to make the two work.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Something wrong with your tranny?
I realize I could probably rebuild it myself fairly easily. Rebuilding things requires time, which I don't currently posses, but a quick day on weekend of swapping one for another at about the same cost as a rebuild (or less depending on what one wants to do). Do I want a shop to do it? No, I do everything on my car myself. So I figured a local shop has a 6 speed for less than 1k and only 65k miles on it vs 168k that my current tranny ran. Therefor the consideration of transmission with lower miles vs. rebuild.
Thanks in advance.
Thanks in advance.
No guarantees here but with some more info I can do some research and hopefully give you a good idea of if it "might" work. I need to know the year of the A4 the tranny is coming from first of all. I looked up 6 speed manuals for 2000 A4's and the only one listed is the EDU/FTG which would obviously work. As I am sure you are aware, ETKA is not set up to show what parts "might" work in certain cars so this will be a guessing game with a good amount of confidence if we can get the right information to start with. Let me know the year of the A4 and I will do my best to get you an answer.
iconoclast
10-24-2007 07:10 PM
in2audi
10-11-2003 01:09 PM
