6spd owners do you have grinding problems to 2nd gear when WOT and shifting fast?
i just changed my tranny oil to redline and do difference. think something is wrong like a major problem. and its only 2nd gear. bad syncro? maybe my tranny hasnt adapted to the new oil? wishfull thinking on my part i guess. anyone else have this problem?
I can't downshift from 2nd to 1st w/out matching revs. This is definitely due to bad 1-2 syncros that are well known in 00 gear boxes (A6 2.7T's and S4's). When the moment presents itself, I'll try a WOT quick-shift 1-2 and see what happens (normally, I like to see the tack travel through the power band in 2nd alone).
but I can appreciate where your coming from. As long as the fluid you put in is within a reasonable range of the specified weight you should be having no problems. In other words, if you have the correct weight oil in the gear box, there should be no grinding downshifting into second, no matter what. This is assuming a good transmission and a good clutch.
