99 A6 starter replacement
#11
$220 is a lot, like I said i got a OEM Remanufactured STARTER AND ALTERNATOR for $220 inluding shipping, from an auto parts seller on ebay.
The solenoid most likely wouldn't be easy to change, and most likely you will not find it sold seperately. Its just better to change it as a unit.
A click with no cranking is definitely a starter/solenoid problem, especially if your battery is good and engine/tranmission are not locked/broken/frozen, etc...
As for tools, I have most of them due to different car maintenance and two alternators thanks to the first one crapping out.
I don't mind doing the work and I don't mind paying the money if it works and gets me back on the road.
It is definitely the solenoid from the sounds of it and the voltage readings.
#12
#13
So I got everything out today but the starter. There is only one bolt and one nut holding it on, but there was only one bolt and that is it. The nut was not there and obviously was never there. However, the starter is seized into position and I can't get it to budge. Anyone have any tricks or ideas how to get it out?
#14
It's a question of how many times you want to start the car. Good luck with it.
This is confusing. You got one bolt out and can't get the other? Can't find the other? Starter is seized in place after bolts are out?
#15
Car started right up and runs perfect now. I do have a grounding problem with the new battery though, but that was not the cause as I tested the starter both while in and out of the car.
vicnorman
17
02-28-2015 06:02 PM
Kevin White
16
01-21-2015 10:55 AM
GuyWithanAudi
07-30-2012 12:51 AM
Harry Katch
10-24-2005 05:19 PM
