a6 2.7t help
a6 2.7t help
I’m looking at buying a 2000 Audi a6 with a 2.7T with a 6 speed with around 100,000 miles on the body. However, the motor is not the original one and was swapped in after the original motor snapped the timing belt. The new motor was installed and then the car sat for a while. The problem it now has is that the cluster doesn’t work and when shifting it makes a beeping sound. Also you can’t get any readings from the obd port. Any ideas or should i run from this project. I do have experience in other turbo cars and doing motor swaps and installs however I have never worked on an Audi, so any ideas of suggestion would be greatly appreciated, Thanks
-Rob
-Rob
The entire instrument cluster does not work, or just the odometer reading?
If something beeps, it could just be a warning to the driver. Could be anything, from a burnt out bulb, to a faulty ABS module.
However, I don't know why it wouldn't read anything from the scanning port. Are you using the correct cable?
The point is that there are so many weird, unknown problems with this car that it could cost you several thousand dollars to make right.
On top of that, it's very likely that the more typical issues(control arms, weak turbos, oil leaks, etc etc) are also present on a car like this, hiding in the shadows of the obvious issues. I would never knowingly buy an engine swap car unless it was very well documented and done at a shop that I know and trust. I've seen it before where a small independent shop puts in a different year/code engine and "makes it work". What a nightmare.
People sell cars like this because they've given up on fixing them. Quit while you're ahead.
