A6 4.2: initial lag on WOT take-off from stand still.
#13
at about 2.5-3k rpm, seems like it's the tip program or a fuel-cut off issue here. anywho, gonna give it another run tonight and see.
-pch-
-pch-
#15
I dont know if this bumping my trans makes is a mechanical or computer problem.. It would not recode on Vag. I did have a problem when i first bought the car the tiptronic did not work at all Audi charged me 800+ dollars to repair the wire harnass which they said had water damage... I only have the problem between gears one and two...I can tell because when in Tip mode I can see on the dashbord display that it holds second gear until i almost stop then bumps into first.. So If i am rolling slowly and step on the gas there is a big sluggish bump from second into first and then the car takes off like it should!!!!!! Should i have had them replace the harnass they wanted close to 4,000 dollars Yikes on my pre purchase inspection they told me that it was not working only because the plastic around the tip shifter was jammed and getting stuck so you could not push it over to the right!!! a new trans they said is 8 grand I would have to sell it,,
engleg
A6 (C7 Platform) Discussion
09-12-2016 05:19 AM
Arnold K.
16
04-23-2012 02:36 AM
Kimchee
03-25-2005 08:00 PM
jslerner
02-25-2001 10:50 AM
