A6 Auto Transmission - Can I Add ATF?
Hello Audi fans,
I did the TB & WP a second time at 165k, and in the process I lost some trans fluid (maybe 8oz lost) while the cooling lines were disconnected.
I know it is the original fluid as I've had the car since 66k.
I bought 1L Pentosin ATF1 fluid in order to replace the fluid lost in the transmission.
Is there a concern in mixing the old with the new?
Thanks,
M.
Thanks,
M.
166k on original fluid? Time to change the fluid and filter.
...and yes, you can add. Even a fluid change doesn't get all the fluid out. Changing the filter is the most important thing.
Have you ever checked/changed the diff fluid?
The trans fluid that came out was pretty clean, so at least I'm not expecting a failure soon.
Thanks for the reply,
M.
M.
xkahn
02-08-2018 10:43 AM
MonSoonHell
09-15-2015 07:14 PM
Jorge Vargas
09-08-2015 07:45 AM
bilbo6209
10
09-04-2015 04:07 PM
