A6 C5 2.7T USA market owners - Please help
Hello,
My car is A6 C5 2.7T APB from USA/Canada market
I can not get rid of the problem:
- P0431 - Warm up catalyst, bank 2, efficiency below threshold
My ECU number
4B0 907 551 T
I found info about possible solution - http://1drv.ms/1jnsEHI
But ASO (Audi workshop) in Poland are useless. They told me that there is no update to my car ECU i Poland and advised me to go to USA for update
Maybe someone have update files to my car? or maybe can download updated flash file from own ECU?
I can flash my ECU by Vag Can Pro software.
I'll be very grateful for any help.
My ECU number
4B0 907 551 T
Witam z Kanady - I'd try new O2 sensors first...
Witam z Kanady!
I have a 2001 A6 2.7T (APB engine US car now in Canada) with 123k miles (nearly 200k km) on it.
My ECU is: 4B0 907 551 Q (not T like yours).
I was getting a similar code, only in very cold weather, for two winters now. My codes was always passenger side (Bank 1) and not drivers side bank like yours.
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
I came across the same article that you found about the ECU re-flash - so you've done good research. In my case I was not interested in getting a re-flash as my ECU is running software form a chip tuner :-).
BTW - the Audi dealer suggesting replacing the entire turbo-back exhaust because it "could be" a clogged cat. I said "no thanks".
I also read on many sites (not just Audiworld) that O2 sensors could be on the edge and failing and decided to replace all 4 O2 sensors. New Bosch O2 sensors after nearly 200k km is a good idea anyway :-) so I thought I'd give it a try.
At my recent service the dealer also found a leaking waste-gate control pressure pipe/hose for passenger side turbo and I had it fixed. Perhaps this was a contributing issue.
I've only had my car back a week since the new O2 sensors and waste-gate fix - but so far no codes and sooooo much smoother driving!
Good luck with yours.
/dan
/dan
I check all O2 sensors and possible leakage from the exhaust.
Update solves problem only with two ECM:
- 4B0 907 551 T (A6)
- 8D0 907 551 L (S4).
If ECM software level of is lower than 4000 - like mine.
Probably in your case update wouldn't help.
I receive info that in USA is official service action for this twoo ECM.
ECM flash is my last option. I already collected 35GB of Audi flash DVD but no sign of flash file to my car...
Audi A6 2.7t APB mt6 ECU 4B0907551AA
redbullgotwings
01-08-2016 04:40 PM
CzesioPL
04-28-2011 11:42 AM
Kimbo Slice
16
11-30-2005 09:05 PM
