A6 C5 white smoke problem //Please help!!!//
#11
#12
Yes, this almost true but not always correct. For example: 2.7T turbos have "oil bearings" another words, they are sleeve bearings that run on a layer of oil. If the shaft seized or any blockage on return, oil shoots straight out to exhaust and it will produce loads of white smoke. How do I know this? Sadly, this is exactly what happened to my car, TWICE, and that's why I am not so fond of turbos (for now). Granted, mine is an exception as many others are very satisfied with their 2.7Ts. Besides, who needs all these boost lags, leaks, diverters, intercoolers etc., when the 4.2 is a power house; smooth all the way! So, I traded up.
#13
A good test for a headgasket leak that is causing white smoke, is to check the spark plugs. If you find one or more that are ridiculously clean(cleaner than new) you definitely have a headgasket leak and the clean plugs indicate where the leak is. Basically water injection, but not metered. If the leak is bad enough, you can get enough coolant in the cylinder for hydrolock to blow the engine(con rods, pistons, head, block), but this is very rare.
I have not had good luck with leak sealers, but some have.
#14
#15
#16
actually not always. overfilling a 911 is an all to common issue to newbies as people dont understand the dry sump system ...
when they overfill and dump oil into the intake it looks like a mosquitto fogger going down the street , but it is always grey/white .. strange i know ..
abpuma
09-17-2015 11:39 AM
Audi A3 2015 Audi All Weather Floor Mats
Colton9182
09-06-2015 06:53 PM
carl viking
09-05-2015 05:31 AM
