A6 quattro 1998 won't crank -HELP
I was driving a while back and my 1998 A6 just started to die and the rpms started to decrease and it wouldn't go when I gave it gas. It died, I tried to start it and it cranked once and then madenthis wierd swirl noise. I checked the timing belt and it was snapped and there is plenty of oil when I checked the dip stick. Im lost and have no idea why it's not turning on. I need the car running soon and don't have lots of money for mechanics to fix it so I'm going to do it myself. If anyone has any ideas please help me out!
are you for real ? your timing belt was snapped and you don't know why it wont turn on ?
Sorry to say that because it wouldn't start you checked to see how much oil it had would tell me you may not have the diagnostic ability or technical knowledge to get this car running .
I'm trying to figure out how you checked the timing belt -- are you sure that it wasn't the serpentine belt that snapped (ribbed belt)?
If the TB snapped, I would think that the motor would be toast... unless you're one lucky ****.
(If it IS the TB that snapped, how did you check it without removing the whole front end?)
If you looked at the front of the motor and saw a broken belt, it's the acessory belt, not the timing belt. Timing belt is behind the covers on the front of the motor. If that's broken, you have likely damaged the valves. If you're not mechanically inclined, get it to a mechanic.
Well that is better desription but sounds not too much better for the car .. looks like you need to get in their and totally assess damage .. Sounds like you need to at least replace the timing belt .. and that is only a start .. if you see one tooth on the belt missing their may be more ..
