abs and brake light come on randomly and then go off
Old 08-29-2008, 12:03 PM
New Member
frepetto's Avatar
Default abs and brake light come on randomly and then go off
i have a 2000 a6 quattro and one day randomly the abs and brake lights came on at the same time with a beeping sound and then they go off after a few minutes... it is really random and i'm not sure why it is happening since i stop fine. my back brakes need changing though... can that be it or what is it?
thanks in adavance...
FR
Old 08-29-2008, 12:28 PM
New Member
ip4me's Avatar
Sounds like the brake switch on your brake pedal
Old 08-29-2008, 12:48 PM
Member
LuvnhatemyA6's Avatar
Default No it doesn't. Sounds like the classic ABS module failure.
How does a faulty brake light switch make the ABS warning light come one?
Old 08-29-2008, 01:07 PM
New Member
frepetto's Avatar
Default Re: No it doesn't. Sounds like the classic ABS module failure.
if its faulty then why doesnt it come on always? also is this dangerous and can something bad happen or can i still drive it with the annoying light that comes on sometimes...
Old 08-29-2008, 01:25 PM
Member
Default The failure mode is often intermittent, at first.
Suggest getting the codes read, as other problems like wheel sensors can trigger the light.
The common issue on the Bosch ABS module is an intermittent communication failure to the module.
A search on ABS module failure will yield more info than you ever dreamed off!
Old 08-29-2008, 01:27 PM
Grapeking's Avatar
Default Luvnhate has it right - your ABS module is failing. You can continue to drive with the
annoying light but be forewarned that you are simply delaying the inevitable - the light will come on more and more frequently until it is always on. As for being dangerous - you'll continue to brake just fine under normal circumstances but your ABS is likely gone.
Your aoptions are to have the dealer change the ABS control module ($1100 to $1200) ot to get a rebuilt one from ModuleMaster or BBA and install it. It is a pretty easy job, would take you about 1.5 hours if you are reasonably hande, and will cost you all of $250 if you have basic tools (screwdrivers etc.) already.
Old 08-29-2008, 01:53 PM
Tech Guru
4Driver4's Avatar
STFA.
Old 08-29-2008, 03:13 PM
donp's Avatar
2nd
Old 08-29-2008, 04:08 PM
jbchinoca's Avatar
Default Strange but true. My 2.8 did that shortly after I sold it. Also included the a/c shutting down,
instrument panel going bonkers.
Old 08-29-2008, 09:16 PM
computrtutr's Avatar
Default Two years....
Ours has done this for 2 years, and we never did anything about it. Our region does not have cold weather often, and the roads are in good repair, and based on the locations we drive to and from, there is little use for ABS (Even on the car with good ABS!). Ours is gone, and we have not prioritized it. The worst thing about it is the randomly-occurring 3 beeps.
BTW, there is a way to repair the ABS module if you are adventuresome. I don't have the link, but STFA and you will probably find it.
Quick Reply: abs and brake light come on randomly and then go off
