Adaptive Headlight Warning
I'm a noob to this car and VCDS and am looking for some help with the warning light I'm getting. I get the annoying adaptive headlight warning everytime I run the car. The lights don't seem to try and auto adjust on startup or around turns. I did just purchase VCDS and below is the error code that it finds. Can someone point me in the right direction on what I need to troubleshoot first or is there a way to disable this feature and remove the annoying code?
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Control Module Part Number: 4F0 910 357 C HW: 4F0 907 357 C
Component and/or Version: AFS 1 H01 0020
Software Coding: 0000016
Work Shop Code: WSC 02327 785 00200
Additional Info: NOSUBSYSTEM AFS-Modul links AFS-Modul rechtsH05 0010
VCID: 264310139112D62ECEF-8073
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 215208 km
Time Indication: 0
Date: 2019.01.16
Time: 17:20:22
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Mileage: 215208 km
Time Indication: 0
Date: 2019.01.16
Time: 17:20:22
Make sure car headlight leveling sensors are intact and in place on suspension control arms. Google is your friend when looking for answers to fault codes.
q5amilehigh
Q5/SQ5 MKI (8R) Discussion
10
05-30-2019 02:14 PM
CobraCommander
01-05-2015 04:23 AM
A8CT
10-14-2006 05:01 PM
