Adding coolant after the T joint near the expansion tank breaks...
Old 05-21-2007, 09:02 AM
signal11's Avatar
Default Adding coolant after the T joint near the expansion tank breaks...
What all is required to properly add coolant to the system after the T joint near the expansion tank breaks? All the coolant in the expansion tank leaked out as well as the coolant in the nearby hoses.
Is it OK to just add coolant or do I need to bleed the whole system? Is there some sort of special procedure that will minimise the amount of air that gets into the system?
Any tips/tricks would be appreciated.
Old 05-21-2007, 09:16 AM
Member
audikillsbmw's Avatar
Default I just bled my cooling system a few weeks ago. This thread should help >
<ul><li><a href="https://forums.audiworld.com/a6/msgs/710300.phtml">https://forums.audiworld.com/a6/msgs/710300.phtml</a</li></ul>
Old 05-21-2007, 09:31 AM
Head Cat Herder
Kris Hansen's Avatar
Just add coolant. I doubt any air got into the block or heater core.
pepp1
3.0TFSI Engine Discussion
12-02-2018 06:16 AM
xips069
02-02-2013 05:42 AM
NiceS4
12-02-2006 07:25 PM
nosey
05-16-2003 09:11 AM
Quick Reply: Adding coolant after the T joint near the expansion tank breaks...
