after changing the batteries in the key fob does the key need to be reprogrammed?
no..
the key does not get programed. The car gets programed to the key. he key has a resistor in it that mates with the imobilizer in the car. The fob battery is only for the transmitter for the lock button.
There's a proceedure, I think it is described in the manual, where you need to use BOTH
key fobs.
Here is what is listed on Stony's links (courtesy of meq123):
1.Take one key/remote (key B) and put it in the ignition and turn the ignition ON (to the "accessory-on" position - don't start the car).
2.Close and lock the driver's door with the other key/remote (key A) while the ignition remains on.
3.Take the key A remote and press the "UNLOCK" button ONCE only - alarm will 'beep'/lights flash, but door will remain locked.
4.Wait for a slow count of 10.
5.With key A, unlock and lock the door again (using the key not the remote).
6.Test the remote by pressing the "UNLOCK" button again - door should unlock.
7.Open the door and turn ignition off and back on again using the key A this time.
8.Continue the procedure for the second remote - close & lock the door with the key B (leaving the ignition on).
9.Take key B remote and press the "UNLOCK" button TWICE - alarm will 'beep'/flash each time button is pressed but door will remain locked.
10.Wait a count of 10 again.
11.With key B, unlock and lock the door again (using the key not the remote).
12.Test the remote by pressing the "UNLOCK" button again - door should unlock.
13.Remove both keys, close the door and perform a final retest by locking and unlocking the car with both remotes.
If this doesn't work, repeat WITHOUT steps 5 & 11.
If that doesn't work, you're on your own :-[
yk7209
02-16-2016 12:54 PM
