after i replace my control arms, what needs to be preloaded?
I replaced the upper, lower, TRD, and sway bar links.
i preloaded the upper, sway bar links, and where the lower shock connects. do i need to preload for the lower control arms?
or any alternate method. I like to jack the suspension up.. I just put an article in teh tech section on replacing the suspension on a C5, it describes this a little.
I drove gingerly, directly to my alignment shop, and slipped my alignment guy some extra $ to really bear down on those, while it was up on the alignment rack. Much easier to do this, with the car 4'-5' in the air, than 12" high.
Just a tip, in case he's DIYing it.
I also do it like this, so I have a LOT more than 12" of room to work.
<img src="https://www.audiworld.com/tech/pics/wheel49_front1.jpg">
method isn't a classic "preloading" such at is on the lowers.<ul><li><a href="http://www.kris-hansen.com/Audi/upper_control_arms.htm">http://www.kris-hansen.com/Audi/upper_control_arms.htm</a></li></ul>
all the bushings attached to the arms?
i had the car up on the lift, and lowered it down onto the lower control arm and it put load on teh suspension. i didnt do it to the lowers though. thanks
The sway bar links. You do not need to do this with teh outer ball and socket bushings.
