AIR BAG warning light after jumping the car
Old 12-25-2000, 06:01 AM
New Member
wws03's Avatar
Default AIR BAG warning light after jumping the car
I had to jump start my 98 A6 Quattro 2.8 yesterday... got really cold.
After the car was started, the "AIR BAG" warning light came on.
Does anyone else ever had this problem?
Is there a real problem with the air bag?
Is there a way to clear this warning myself?
Does my airbag still work partially if this light came one?
thanks!
Old 12-25-2000, 06:29 AM
Elder Member
Jon C's Avatar
Default Jump starting modern cars is very risky
the computers are extremely sensitive to voltage fluctuation & spikes. You may have gotten a surge that fried something.
No, you can't reset it yourself AFAIK; can't tell if the airbag itself works if the light's on because we don't know what the fault, if any, is. My 94 MB C280 regularly had seat switches go bad, setting the SRS light off: you never knew which switch was bad; the bad switch disabled the bag associated with it, the other bag would work.
Get it checked by your dealer.
Old 12-26-2000, 03:42 AM
AudiWorld Uber User
April's Avatar
When jumping a modern car, use the "through the lighter socket" jumper for safety.
Old 12-26-2000, 05:37 AM
BobT(nolonger)A6's Avatar
Can the lighter circuit safely carry the kind of current needed to start the car?
Old 12-26-2000, 07:34 AM
Elder Member
Jon C's Avatar
Yep, that's what I use. Or I disconnect the battery & charge it.
Old 12-26-2000, 09:08 AM
rap
New Member
rap's Avatar
Short answer is no. Presume April refers to trickle-charge method.
Old 12-27-2000, 05:44 AM
That's what I thought. Difference between 'jumping' and 'charging'.
Old 12-27-2000, 09:38 AM
Elder Member
Jon C's Avatar
Default Short answer, actually, is yes. There are chargers that will do this...
I got one from Brookstone a couple of years ago. It's not really a trickle charger because IIRC it takes only a few minutes to build the charge (whereas a trickle charger is charging in milliamp increments, taking hours).
bladeofgrass
02-28-2010 02:16 PM
Stander V6
Audi 100 / A6 (C4 Platform)
09-21-2005 07:20 PM
jw38
14
01-28-2003 04:53 PM
shrtbus(w/ cq)
06-11-2002 04:23 AM
PoorHungryDoctor
07-25-2001 06:27 AM
Quick Reply: AIR BAG warning light after jumping the car
