airbag circuit diagram
<center><img src="http://pictureposter.audiworld.com/100734/img_0004.jpg"></center><p>I used to be able to connect to the airbag and the airbag light was not on, now I cant connect and airbag light is now on perm.
I am thinking maybe its the power for the airbag controller, Have checked fuse 15, but thats about as far as I have got, reason being I cant find T3a/3 the black connector point right A piller, I have found a black connector but it doesn't have the right coloured wires going to it. should be according to the diagram Black, Green/Red, White/Yellow
my black connector has White, Yellow/Black, Red/Yellow, Brown/Green
so I dont believe its the right one. can anyone point me in the right direction?
If a code is lodged in the control unit, all the wiring diagrams in the world won't help the light go off.
I cant connect to the controller... would be great to be able to clear the code!!!
yes, this is why i think its either the power +12 v connection to the controller,
the earth connection to the controller or the K (data) connection to the controller.
if i can establish there 3 things then I might get vag to work, then can establish if any of the sensors have gone..
the light only came on when i removed the passenger seat then started the car to move it.
I'd try a few things:
Disconnect the radio and see if you can connect.
Check the connector for bent pins.
Uplug all the aig bags and try to connect.
It's unfortunate that the cluster diagram doesn't show whether the indicator light looks for power or ground from the Air bag controller. If power it would be obvious that the unit has power.
