Airbag light on!
Hi there. working on a 99 A6, 2.8l. Airbag light is on. Assume module is pouched? where is it located? can I plug n play one from a '02 S8?
Use VAGCOM/VCDS to diagnose the problem. It might be the module, or it might be something cheaper and easier to fix. The module might be the same, or it might be different. Make sure that it has the same part number on the label attached to it.
On the A6, the airbag module is located underneath the climate control module, attached to the chassis.
If you just bought the car, it could also be a phony airbag cover put on after the airbag has been deployed rather than buy a new airbag at $1400….
A6girly
11-09-2006 09:09 AM
