Allroad engine blown, should I sell or swap?
#11
What engine? It may not be as big a deal as you think. Find a reputable indy shop and give them a call. A simple compression test will tell the story.
#12
#15
I have NJ places listed here. Not sure how close you are to any of them, but might be worth a call to see what a ' head replacement' will cost you. You can usually get the heads off eBay for reasonable money. Probably 300 each or so
http://www.VAGLinks.com/#Speedshops
Hope that helps
Cheers
Massboykie
Hope that helps
Cheers
Massboykie
#16
Hope that helps
Hope that helps
#17
Replace valves, not heads.
Unless a valve head snaps off and pounds the crap out of the head, there is no need to replace.
Further, get a belt back on there first and do a leak down test. Sometimes you get lucky and the damage is confined to one side.
Diagnose first, then fix.
#18
I agree with 4driver4. Get it tested to see what all the damage is before you go buying new heads.
Taking the heads off is not a simple procedure compared to a leak down test. Do the simple stuff first.
Lil Tiger
A4 allroad (B8 Platform) Discussion
10-21-2020 02:23 PM
N'Syncro
33
02-16-2020 03:12 PM
Audi R8 2009 Audi R8 3k miles!
One_Murphy
09-04-2015 06:40 AM
