Any reliability issues with the A6 2.7T
Old 07-01-2002, 04:24 AM
New Member
chefwong's Avatar
Default Any reliability issues with the A6 2.7T
I'm plannning to get one myself but I read somewhere that the A6 has some reliabilty issues in addition to shaking issues.
I did a quick web search....and the A6 is on quite a bit of the "lemon" lists. Any comments from current A6 oweners ?
Old 07-01-2002, 04:33 AM
Wireless's Avatar
Default no problems here except a coolant sensor warranty repair
other than that, I've trashed my brakes, but that's due to my unusually spirited driving.
Old 07-01-2002, 05:08 AM
Potomac-Greg's Avatar
Default Small problems affected 2000/2001 models. Most seem reliable and...
... more importantly, one of the great auto values out there. First rate interior and a very strong engine.
There are one or two examples on this list of "lemony" cars, but overall, it's limited to minor, non-functional problems.
Old 07-01-2002, 05:32 AM
Audi S5 TC's Avatar
Default Re: Any reliability issues with the A6 2.7T? Some.
The 2.7T (mainly early 2000) is very largely the reason the A6 is on a lot of the lemon lists. Other variants of the A6 2.8/3.0, 4.2 and S6 seem to be much more reliable. In fact CR rated the A6's reliability average or better than average and recommended it from 1998 to 2000. From 2000 to present CR rates the A6's below average and does not recommend it. The reason? Literally all A6 owners surveyed from 1998 to 2000 had the 2.8 variants. From 2000 to present most or all of the A6 owners CR surveyed have the 2.7T variant, mainly early 2000. I know all of this because I have been reading CR very frequently since 1998. I believe the shaking or vibration issues are nearly as common or just as common on many BMW models and more common on the Lexus IS and 1998+ Lexus GS.
Old 07-01-2002, 05:56 AM
New Member
LMcGrath's Avatar
Secondary water pump at 11K..... no other probs so far
Old 07-01-2002, 06:39 AM
AudiWorld Expert
2.7tDallas's Avatar
Default Well - I have an early prodcution 2000 model. As it gets later, it gets better
Do I have to post the WHOLE list again????/
myfirstimport's Avatar
Many problems for me....but still the best car i have ever had.....I can't wait to buy my next one
Old 07-01-2002, 07:50 AM
Elder Member
Bollinger's Avatar
Default gobs of trouble here too
October 1999 build, Took 2.5 years before I went 6 months (an oil change) without a check engine light.
Reliability has been much better with later models.
I recommend the car.
Old 07-01-2002, 07:53 AM
AudiWorld Expert
2.7tDallas's Avatar
Default I LOVE mine now that most everything has been fixed, but (here is the list)
7/99 build date
o2 sensor
Two (2) water temp sensors
Seat heater switch
Seat heater element wiring
Seat bracket
Lower drivers seat leather and springs
Radio
Three (3) Fuel Sender Recalls trips
Headlight washer pump
Various cup holder 7 times
Rear Brake Rumble - still investigating
Two (2) window regulators/tracks
Fog light bulb
Front Turn signal bulb receptacle (burned) x2
Replaced front bumper due to a repainted used part
Bad paint on rear bumper skin that is a repainted used part - still in negotiation
Battery failed at 26k Miles
Throttle Body Boot
Mass Air Flow Sensor
By Pass Valves - replaced at my cost.
Two (2) valve cover gaskets
Two (2) cam cover gaskets
Front upper tie rod ends (2)
Old 07-01-2002, 08:12 AM
Audi_RKT....(Bedros)'s Avatar
Default 01/01 built. Very solid, just put gas and change oil
I highly recommend the A6 2.7T, a very solid car and fun to drive. It's faster than E-class and BMW 5 series, larger interior and huge trunk.
After 20K I had no problems except a stuck cup-holder in the back seat which was replaced under warrently.
Quick Reply: Any reliability issues with the A6 2.7T
